It is currently Sat Apr 20, 2019 2:54 am
 Post subject: skyhawk, d33007, bios
PostPosted: Sun Apr 20, 2008 11:20 am
Need to know what a bios chip looks like for a skyhawk d33007
PostPosted: Sun Apr 20, 2008 12:57 pm
Why do you need to know that? It is a board specially made for Compaq/HP, most likely by FIC and there's no known retail equivalent.
 Post subject: because
PostPosted: Sun Apr 20, 2008 3:17 pm
I just want to know where it is
PostPosted: Sun Apr 20, 2008 4:26 pm
Likely there will be a decal on top of a small chip, about 3/4 inches square.. noting either Award Bios, Phoenix Bios, or Compaq Bios.. maybe even AMI Bios. The chip could be surface-soldered to the mobo, or in a square socket.
Don't attempt to remove the BIOS chip from a socket, unless you have the special extracting tool!
PostPosted: Tue Apr 22, 2008 10:21 am
With the I/O ports facing you, in the upper right corner in a brown square plastic holder.
http://www.elhvb.com/ctechinfo/model/sk ... yhawkL.php
PostPosted: Sun May 11, 2014 5:56 am
Digging through looking for information, and filling in the blanks where I can.
The board is made by FIC (First International Computer), for Compaq/HP. There is still no known retail equivalent though.
The codename is SKYHAWK.
SKYHAWK-L simply means it is equipped with LAN, as near as I can tell.
http://www.ctechinfo.net/boards/fic/skyhawk.php
Compaq-Fu Master
