Win98se or XP
Win98se or XP
Postby Darkstar_Surfers » Tue Dec 30, 2003 10:11 am
I have been using win98se for the past few years and have had no end of problems with my system. Either a faulty hard drive or a virus evey few months. Either way I need to re-build yet again as my system is unstable and getting to be a real pain. I have aquired a copy of XP only to be told to stick to win98se as XP will kill my system.
What do you think.
I have
Asus A7A266 with AMD1400
640M of 133
Voodoo3 3500 TV
120G Caviar EIDE 7200rpm
52x32x52 CD-RW
DVD Rom
Darkstar_Surfers
Postby Toby B. » Tue Dec 30, 2003 10:25 am
640 MB of RAM??? :? what size chips are you using? Do you mean 64MB?
As far as Windows 98SE or Windows XP, its just a matter of preference. I like it, freinds of mine that have it hate it with a passion.
XP is more driver freindly than 98SE, but is more tempermental with big hardware changes.
The minimum recommended amount of RAM for use of Windows XP is 128MB, The more you have installed the better off you are.
Toby B.
Postby Darkstar_Surfers » Tue Dec 30, 2003 1:22 pm
I have two 256M and one 128M, I think that adds up to 640M.
Thanks for the pointers
Darkstar_Surfers
Postby Aussie » Tue Dec 30, 2003 1:25 pm
640 MB of RAM??? what size chips are you using? Do you mean 64MB?
1 x 512 + 1 x 128 = 640Mb for example. :P
Darkstar_Surfers your hardware is more than capable of running Windows XP and I'm sure that you will find it a more stable and capable operating system than Win98 ever was although you can't blame any OS for hard drive failures or viruses.
It might pay to search for WinXP drivers for your add in cards & peripherals before you install the operating system just to be on the safe side.
Just be sure to visit Windows Update as soon as you get the OS loaded and grab all of the critical updates needed.
Aussie
Aussie
Postby miki02131 » Tue Dec 30, 2003 1:27 pm
With that amount of RAM, you should definitely go with XP. There is no doubt about it. Actually I recommend XP Pro.
Sorry to say that but I don't think the rules you use to add two 256 to 640 exist.
Help humanity .....join the
Motherboards.org
folding team! 33258
miki02131
Postby Darkstar_Surfers » Tue Dec 30, 2003 3:32 pm
Just checked.
Under 'My Computer', 'System' it does say I have 639M.
Still I thought 256 + 256 +128 is 640, I seem to have lost a M some where, never mind, I never was good at arithmetic.
Darkstar_Surfers
Postby FatMikel » Tue Dec 30, 2003 3:58 pm
256 + 256 ( 512 ) + 128 = 640, you lot sure are bad at maths. lol :lol:
go for windows xp home or professional, both are good, pro has a few more security features and network things.
FatMikel
Postby Tolemac » Tue Dec 30, 2003 6:42 pm
I have to agree with everyone else. XP would be the thing to do. :wink:
Tolemac
Postby beeboy » Tue Dec 30, 2003 7:55 pm
Yes. Go with Xp. Easy to install. Xp has excellent hardware support. I dont have to install a single driver for mine including printer and scanner.
beeboy
Postby BrevCampagnolo » Tue Dec 30, 2003 9:52 pm
That missing 1MB RAM probably means you have hardware that does crunching but doesn’t have a processor. The OS doesn’t see that one MB because the hardware has commandeered it. On-board video would’ve been my first guess but I see you have a Voodoo3 in your SysSpecs.
As for the OS, XP definitely is the least evil of all Microsloth’s desktop OSes. And it does a happy dance if you have 512MB RAM or more, so you’re golden there.
If you go with XP, be prepared for the massive updates. Between SP1 and all the necessary security updates, you’re looking at ~200MB of downloads. You can cut that down to ~65MB if you use an XP installation CD that has SP1 incorporated. It’s called slipstreaming, and doesn’t come on MS disks; you’d have to find a friend/acquaintance who’s created the slipstreamed installation CD.
-- Campy
"Computers in the future may weigh no more than 1.5 tons."
- Popular Mechanics, 1949
BrevCampagnolo
