building a PC
Postby ils_fl » Tue Aug 26, 2003 12:19 pm
its a hobby of mine
i am an industrail designer :twisted:
________
No2 Vaporizer
ils_fl
Postby ils_fl » Tue Aug 26, 2003 12:51 pm
ok, what exactly is a chipset number.
i think i'm going to go with Abit IC7-G , P4 3.0 GHz, 800 MHz FSB.
the stats are intel 875 chipset.
the site is unclear what ram is most compatibe
Supports up to 4GB of Single/Dual channel DIMM modules, delivering bandwidth of 4.8GB/sec
________
GLASS PIPE PICTURES
ils_fl
Postby GEFORCEFreek » Tue Aug 26, 2003 1:51 pm
Abit = Manufacturer
IC7-G = Motherboard Name
800Mhz FSB = Front Side Bus Speed
Intel 875 Chipset = The Chip that the Board uses
Supports up to 4GB of Single/Dual channel DIMM modules, delivering bandwidth of 4.8GB/sec= you can use DDR of any speed using single or dual channel.. 4.8Gb/s is the Memory Bandwidth.
:P
GEFORCEFreek
Postby ils_fl » Tue Aug 26, 2003 2:00 pm
OK good that what i thought. :D
________
Toyota p transmission
ils_fl
Postby Quiksilver4871 » Wed Oct 01, 2003 1:24 am
I have had good expirences with abit, u mite wana check those out
Quiksilver4871
Postby Grayman » Sat Nov 01, 2003 10:21 pm
the asus p4c800 deluxe seems to be a good canidate
Grayman
Postby Tulatin » Sat Nov 01, 2003 10:23 pm
Have you built this beast yet dude? I'm sure when the time comes to (if you haven't) there'll be an abit in that case.
Tulatin
Postby ils_fl » Sun Nov 02, 2003 2:14 am
yes i have
well i started with a 10 dollar case and just cut some holes in it for the fans for now - will mod it later.
well what i have
abit ic7
p4 2.8Ghz with HT at 800Mhz fsb
corsair 1024 ddr 400 pc3200
ati radeon 9800pro 256MB
cpu cooling - slk900 with 80mm tornado fan
two 80 mm fans for intake and side intake
enermax 450w PSU
LG burner
LG reader
didn't care so much about sound so don;t have it yet.
ils_fl
A Little Somethng
Postby bruhthaKuga » Sun Nov 02, 2003 9:27 am
Someone mentioned cases for AMDs, One don't have to be scared about the fact that AMDs run hotter, just aware and responsive. The best cases for AMD have a fan outlet just below the power supply as this is where the CPU is usually located and is the worst location for the CPU cause the bottom of the P/S provides a corner for heat to collect. If your case doesn't have the fan outlet for the CPU you must get an AMD rated powersuply as they have a second fan on the bottom to suck away the heat. Both are fab. If you don't have an AMD rated P/S or a fan outlet but you do have an extra 80 size fan and a bit of fabricating experience you can cut out a fan outlet on the side of your case mount the fan and add a little tubing to focus the blast on the heat sink and voalla!
bruhthaKuga
Postby Tulatin » Sun Nov 02, 2003 11:51 am
Nice. But you may want to get a hardcano 9 to hook that tornado to so you can throttle it down. At high and low, there's not much diff in temps.
Tulatin
PreviousNext
