It is currently Sun Sep 23, 2018 8:39 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
 Post subject: My new PC
PostPosted: Sat Aug 09, 2003 9:23 am
*edited* sorry I was wrong to brag...
PostPosted: Sat Aug 09, 2003 12:06 pm
Man, what do you do for a living? When the hell do you get all of this money....and if you can afford a 50 inch plasma monitor why dont you think about getting a dual xeon system?
PostPosted: Sat Aug 09, 2003 12:30 pm
if you really need to know just check my profile.
I don't want to build Xeon PCs because it isn't what my company does....not enough market for home dual Xeon PCs. :)
PostPosted: Sat Aug 09, 2003 2:04 pm
what exactly does your company do
PostPosted: Sat Aug 09, 2003 11:09 pm
VERY NICE Josh! Now, is the aquariu kit still running it's sttock pump, and if so, how's the water flow? If not, what did u replace it with. Now, what vid card and chipset blocks do you have?
PostPosted: Sat Aug 09, 2003 11:24 pm
sorry I'm not allowed to say on the forum posts. its against Motherboards.org rules to advertise a company or business......I'll PM you.
PostPosted: Sat Aug 09, 2003 11:47 pm
Sorry Tulatin that last post was for Smurf_Pimp.
OK now... Yes Tulatin I am running the stock pump but have reduced the flow of water to the CPU block because the water system is not the primary CPU cooler and is only needed to keep the peltier plate cool. I used a small tube inserted into the main water tube going to the CPU block to reduce the water flow....this as a result increases the water flow to the VGA and the northbridge blocks.
I'm using...a Wildcat 4 7210 384meg 256-bit DDR Dual processor 8x AGP VGA card so I have 2 blocks for that and one more for the southbridge. the blocks are by WaterChill.
Tell you what I'll list the equipment I'm using and place a link under each one so you can view it....is that allowed? can I hear from one of the moderators on that?
PostPosted: Sat Aug 09, 2003 11:50 pm
Yeah linking to hardware is legal. You are somewhat paranoid man. The don't advertise rule applies to blatant ads, not your job, and the don't make money here is essentially the golden one, exempt to teh buy barter and sell forum. But yes, you can link, and don't worry, i f you do something wrong, the mods will tell u about it, u fix it, and you'll be knwo not to repeat in future.
PostPosted: Sun Aug 10, 2003 6:39 am
I'M NOT PARANOID>>>>>WHO TOLD YOU THAT>>>WHO HAVE YOU BEEN TALKING TO. WHY ARE YOU PERSECUTING ME LIKE THIS.
PostPosted: Sun Aug 10, 2003 8:16 am
Hehe sorry bout that don't know what came over me. AHEM!
Anyway:
Here are the links to some cool gear
Corsair XMS TwinX 1024-4000 RAM
http://www.corsairmemory.com/main/produ ... 4-4000.pdf
http://www.corsairmemory.com/main/PR_xms4000.html
Asus P4C800 Deluxe mobo
http://usa.asus.com/products/mb/socket4 ... erview.htm
WD SATA 250GB 7200rpm 8meg
http://www.wdc.com/en/products/wd2500jd.asp
WD Raptor 360GD SATA
http://www.wdc.com/en/products/WD360GD.asp
LGE GSA-4040B DVD Burner
http://www.lgeus.com/Product/CD/GSA_4040B.asp
Samsung SW-252B
http://www.pcstats.com/articleview.cfm?articleID=1063
3DLabs Wildcat4 7210 384meg
http://www.3dlabs.com/product/wildcat4/index.htm
SoundBlaster Audigy2 Platinum 24bit
http://singapore.creative.com/products/ ... 2platinum/
Thermaltake SubZero4G thermo-electric (Peltier) cooling (heavily Modified)
http://www.thermaltake.com/products/sub ... o4g.htm#p4
Thermaltake Xaser III Super Tower V1420AU
http://www.thermaltake.com/products/xaser3/v1000a.htm
Thermaltake W0010 Silent Purepower 480W Xaser Edition PSU
http://www.thermaltake.com/products/pur ... 001011.htm
1 x Thermaltake AquariusII water cooling system (modified)
http://www.thermaltake.com/products/Aqu ... riusII.htm
2 x Thermaltake Active Memory Cooling Kit (for the RAM)
http://www.thermaltake.com/products/mem ... vekits.htm
The Astek link is hard to get to so heres some from kustom PCs
2 x Astek WaterChill VGA Cooler - VGA01/P1 03-L-2001
http://www.kustompcs.co.uk/product.php?view=2623
1 x Astek WaterChill Northbridge Chip set cooler - NB01/P1
http://www.kustompcs.co.uk/product.php?view=2624
1 x Vantec Iceberq CCB-A1C Chipset Cooling Kit (for Southbridge)
http://www.pcabusers.com/reviews/iceberg/p1.html
*I have edited this post as I felt it was showing off*
