It is currently Mon Aug 03, 2020 6:37 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jul 20, 2003 7:06 pm
Yep, for peace and quiet I run a PIII 600 with only the cpu fan and (double) psu fans. No case fan, nice and quiet, more or less unchanged temps. 2 years never switched off!
PostPosted: Sun Aug 10, 2003 11:38 am
How about that previus note on a business rating and a gamer rating.
On the business side, the ratings would have to adjust, or maximize. Example.... if the speed linit is 25mph, Having a car enigine with 150hp or 400hp just doesn't matter. In this case, both engines would be rated he same.
On the gamer side, the fps seems like a good one, but again, if a game plays well at 100 fps..... and having a 400 fps doesn't make for a play difference in the game, the cpus would be rated the same.
The ratings would need to be made by a 'disinterested' 3rd party.
I have to tell you, my XP2500+ and my old P3 run Excel just the same. For home use, my P2-350 is absolutely fine.
Business rating P2-350 100, P3 110, XP2500+ 110
Games are different. Quake 2:
Game rating P2-350 100, P3 180 xp2500+ 400
These are just my 'gut' ratings.
MB AsusA7V8X-X
CPU 2500+ Barton
VID E-VGA Geforce 6600GT
Aero7+ Cooling under load @1700 45c
Crucial 2x256 pc2700
Cheap Case with lots of custom holes!
