It is currently Sun Sep 23, 2018 11:56 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Which do you see more on 98?
Blue Screen 43%  43%  [ 3 ]
Your Screen Froze 57%  57%  [ 4 ]
All your open folders echoing across screen 0%  0%  [ 0 ]
Total votes : 7
PostPosted: Wed Mar 05, 2003 5:16 pm
I've never had any problems with Win98SE either. Worked like a charm, it took me a lot of courage to switch to XP Pro. But now that I'm settled in have to say I like XP Pro features much better.
-R
PostPosted: Thu Mar 06, 2003 11:06 am
I am the same way, but I still detest the way XP wants to automate everything for me. I like an operating system to do only what I tell it.
PostPosted: Fri Mar 07, 2003 9:00 pm
What kind of cable modem are you using ? Windows doesn't even know I have a cable modem. I have had RaodRunner cable in Kansas and Comcast here in Denver. Never had any Windows/Cable Modem problems at all.
PostPosted: Wed Mar 12, 2003 1:54 pm
98 works just fine on my cable modem. None of the above on the poll vote.
PostPosted: Fri Mar 21, 2003 2:38 am
so why does the screen always freeze on win 98 se when your a cable user?
.............................rhysp3ct...........................
Strange that we all defend our wrongs with more vigor than we do our rights.
PostPosted: Thu May 01, 2003 3:10 pm
I am using Win 98 SE with my cable modem and never had a crash as a result of the modem. Windows itself does not drive your modem directly but your ethernet card through which the modem is connected to the computer. So if you're experienced any problem, you might need to update your ethernet card driver Or look at other component conflicts.
Also one needs to understand windows networking is not optimized by default for high speed internet, but for dial up. To significantly increase your internet performance, you need to implement certain reg tweaks. You could either do them manually if you feel comfortable editing your registry or you could use special utility to implement the tweaks. Either way, to get a cable modem to perform better on win 98SE , one needs to optimize the networking components for high speed internet.
Help humanity .....join the
Motherboards.org
folding team! 33258
PostPosted: Fri May 02, 2003 5:30 pm
I've had no trouble at all with Cable and Win 98SE. It runs GREAT. It might have more to do with your hardware if you are experiencing problems.
So...I can't vote on this topic cuz I've experienced neither of those problems due to my cable connection.
-R
