It is currently Thu Jan 17, 2019 7:36 am
PostPosted: Fri May 17, 2002 6:46 am
Damn!!! I'll bet that unit sounds like a P-51 Mustang in a full power dive with all those fans.
Aqualung my friend --
don't start away uneasy
you poor old sod, you see, it's only me.
PostPosted: Sun May 19, 2002 7:22 pm
:arrow: :!: here's a link to a configuration that has 55 nodes (72 processors):
http://www.mosix.org/
PostPosted: Sun May 19, 2002 7:27 pm
Man do I wish i had the money for a project like that.
PostPosted: Sun May 19, 2002 7:58 pm
:arrow: :idea: :!: why don't you implement it w/ your own server- isn't linux essentially unix (you've got fic503+ systems-2 or 3?)? states that it can be use different speed processors- work out the format in small scale. came upon this while checking out the forums at linuxiso.org- they were talking about seti- figured i'd post it here.
finally checked the iso cd's that i created a month ago w/ md5sum file check- they look good. situation is, it's been a month since i burned the cd's, and redhat 7.3 was a beta then, now it's released, so i don't know if i should make 7.3 cd's, or load the 7.2 version- does the upgrade work ok, or like w/ windows, is a full install best?
PostPosted: Sun May 19, 2002 8:52 pm
I've got 4 now actually running various O/S. Eventually I will have a Linux system running SETI deticated all the time, but the box I have right now is having trouble getting SETI to work (inheriant hardware issue).
Right now I've got a box running SETI under Windows, but its not very fast.
Parrallel computing like in that photo is very fast, the more computers, the more data is computed.
