It is currently Fri Sep 21, 2018 12:17 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: change the time?
PostPosted: Fri Jul 15, 2005 10:56 am
is there any way to change the time ?
PostPosted: Fri Jul 15, 2005 11:00 am
no im afraid it fixed , this was decided many hundreds of years ago, by people no longer a live today :wink:
PostPosted: Fri Jul 15, 2005 11:02 am
o that sucks o well
PostPosted: Fri Jul 15, 2005 11:04 am
or do you mean forum time
PostPosted: Fri Jul 15, 2005 11:05 am
the forum time lol of course i didnt mean actual time
PostPosted: Fri Jul 15, 2005 11:06 am
Quote:
The times are not correct!
The times are almost certainly correct; however, what you may be seeing are times displayed in a timezone different from the one you are in. If this is the case, you should change your profile setting for the timezone to match your particular area, e.g. London, Paris, New York, Sydney, etc. Please note that changing the timezone, like most settings, can only be done by registered users. So if you are not registered, this is a good time to do so, if you pardon the pun!
PostPosted: Fri Jul 15, 2005 11:14 am
wow im blind as a bat i guess i didnt c it when i looked would you happen to know which 1 to put it on for the time zone of ny ?
