broken code?
broken code?
Postby colinJohn » Sun Jul 03, 2005 5:21 am
I'm seeing all the html when I press the submit button on a post again; has something been changed recently? - I've not had this problem for a while.
XP SP2 - up to date
firefox v1.0.4
eg
Server: Apache
X-Powered-By: PHP/5.0.3
Set-Cookie: mothforu_phpbb_data=a%3A2%3A%7Bs%3A11%3A%22autologinid%22%3Bs%3A32%3A%22d266fc876acd3e13b6108b0409e3dc80%22%3Bs%3A6%3A%22userid%22%3Bi%3A196105%3B%7D; expires=Mon, 03-Jul-2006 13:16:35 GMT; path=/forums; domain=.motherboards.org
Set-Cookie: mothforu_phpbb_sid=8c16c06b51695535c8b6ab568b010f9e; path=/forums; domain=.motherboards.org
Set-Cookie: mothforu_phpbb_t=a%3A28%3A%7Bi%3A74972%3Bi%3A1120383399%3Bi%3A75286%3Bi%3A1120382665%3Bi%3A75064%3Bi%3A1120293234%3Bi%3A75296%3Bi%3A1120288312%3Bi%3A75309%3Bi%3A1120300107%3Bi%3A75307%3Bi%3A1120288490%3Bi%3A75312%3Bi%3A1120288510%3Bi%3A75297%3Bi%3A1120387476%3Bi%3A75195%3Bi%3A1120293307%3Bi%3A65440%3Bi%3A1120293638%3Bi%3A75316%3Bi%3A1120383427%3Bi%3A75295%3Bi%3A1120297872%3Bi%3A75216%3Bi%3A1120300024%3Bi%3A75324%3Bi%3A1120310191%3Bi%3A75321%3Bi%3A1120385031%3Bi%3A75247%3Bi%3A1120382625%3Bi%3A75356%3Bi%3A1120384845%3Bi%3A75273%3Bi%3A1120384872%3Bi%3A75326%3Bi%3A1120385149%3Bi%3A75339%3Bi%3A1120385215%3Bi%3A75325%3Bi%3A1120385287%3Bi%3A75328%3Bi%3A1120385466%3Bi%3A75361%3Bi%3A1120385504%3Bi%3A75360%3Bi%3A1120385518%3Bi%3A75367%3Bi%3A1120396595%3Bi%3A75366%3Bi%3A1120395142%3Bi%3A75332%3Bi%3A1120395185%3Bi%3A75327%3Bi%3A1120395468%3B%7D; path=/forums; domain=.motherboards.org
Cache-Control: private, pre-check=0, post-check=0, max-age=0
Expires: 0
Pragma: no-cache
Keep-Alive: timeout=15, max=100
Content-Type: text/html; charset=UTF-8
Transfer-encoding: chunked
576
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html dir="ltr">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta http-equiv="Content-Style-Type" content="text/css">
<meta http-equiv="refresh" content="3;url=viewtopic.php?p=523452#523452">
<link rel="top" href="./index.php" title="The Mother Board Forum Index" />
<link rel="search" href="./search.php" title="Search" />
<link rel="help" href="./faq.php" title="FAQ" />
<link rel="author" href="./memberlist.php" title="Memberlist" />
<title>The Mother Board :: </title>
<link rel="stylesheet" href="templates/motherboards_org/motherboards_org.css" type="text/css">etc etc
"It's the best that there is"
colinJohn
Postby colinJohn » Sun Jul 03, 2005 8:57 am
weirder and weirder..... a search gave me this repeatable error message
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 16 bytes) in /home/virtual/site1/fst/var/www/html/forums/search.php on line 362
searched using author's name (Karlsweldt) and keyword (BIOS)
needed to find his neat reset PnP trick.....
colinJohn
Postby Tolemac » Sun Jul 03, 2005 2:35 pm
Nothings been changed that I'm aware of. MoboCop usually informs us mods if something is going to happen, and he has not for a while now. If you still have IE, would you try it in that and see if you still get the same thing happening.
Tolemac
Postby colinJohn » Sun Jul 03, 2005 10:54 pm
I can no longer repeat the the displaying code problem - everything seems ok with posting
but the search error is still there for both IE and FF. If I enter anything in the search boxes it comes back with this error message
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 131072 bytes) in /home/virtual/site1/fst/var/www/html/forums/search.php on line 366
colinJohn
