Eliminate Froms from Unread Posts Function
Postby Big Jake » Thu Jun 30, 2005 1:46 pm
The feature "View posts since last visit" is very helpful and is a real asset for those of us who want to help the folks who are posting questions that need our collective expertise.
Is there a way to eliminate specific forums from the search "View Posts Since Last Visit"?
I find the "Hundred Years Wars" and "Water Cooler" threads are a big waste of my time and would like to excliude them from my search for whats been posted since my last login.
Thanks, Jake
Big Jake
Postby Toby B. » Thu Jun 30, 2005 5:33 pm
That is something better addressed to phpBB directly.. Not here.
Toby B.
