strange display error
Postby colinJohn » Sun May 01, 2005 2:43 am
I'm getting the "new topic" icon at both the top and bottom left hand side of the forums cut in half for some reason
using Firefox, XP Home SP2
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.7.7) Gecko/20050414 Firefox/1.0.3
no problem with IE v6.0
"It's the best that there is"
colinJohn
Re: strange display error
Postby EmilyB » Sun May 01, 2005 2:47 am
colinJohn wrote:no problem with IE v6.0
:wink:
EmilyB
Postby colinJohn » Mon May 02, 2005 10:25 am
well, it seems ok now :-)
colinJohn
Postby EmilyB » Mon May 02, 2005 11:25 am
colinJohn wrote:well, it seems ok now :-)
BTW you do know this forum is for posting problems about the main site and not the forums dont you? :P
EmilyB
Postby colinJohn » Mon May 02, 2005 12:59 pm
well I guess I do now :-)
colinJohn
