avatars and pix
avatars and pix
Postby sloopdog 1 » Thu Mar 31, 2005 8:26 am
wassup with the avatars and pix?not all will load. all I see is white square with red x. :cry:
No keyboard detected-Press any key to continue.
sloopdog 1
Postby EmilyB » Thu Mar 31, 2005 8:36 am
This issue has been explained in the past many many times.
Since all the Sigs and Avatars are hosted in several different places, it all depends on the status of the hosting website. For example if www.uploadit.org has a problem then any Sigs and/or Avatars hosted there (like mine) will not be shown on here.
This is not a forum issue.
EmilyB
Postby snap355 » Thu Mar 31, 2005 8:37 am
I see yours just fine
[/url]
snap355
Postby sloopdog 1 » Thu Mar 31, 2005 1:07 pm
Was at werk earlier,could not see but just a few avatars and pix.At home now,all ok.
sloopdog 1
Postby Toby B. » Thu Mar 31, 2005 7:13 pm
As pointed out already, this is a problem with other servers, not motherboards.org. Therefore we have absolutely no control over it...
Toby B.
