Everything gets marked as read too soon
Postby headofmax » Wed Mar 30, 2005 11:12 am
sometimes I log on at school or work, and I don't have time to look at
evertyhing. If I log off then log again later, everything is marked as read
even though I haven't read it.
DFI Lanparty Venus
Opteron 165 @ 2.8
Thermaltake Big Typhoon
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
Hannspree HW191D widescreen
headofmax
Postby EmilyB » Wed Mar 30, 2005 2:16 pm
Yes this happens all the time. As soon as you logout every thread updated prior to logging out will be marked as read. Any thread that is updated whilst you are logged-out/offline will be marked unread as expected. This does seem a little odd but I always assumed it was a Cookie issue.
EmilyB
Postby Wyrm73 » Wed Mar 30, 2005 2:19 pm
Are you talking about the colored icons for new posts since your last visit? If so, it does this automatically as Emily said. The next time you log on, the posts you have not read are no longer colored, but the title shows up in bold if that helps.
Wyrm73
Postby headofmax » Wed Mar 30, 2005 2:28 pm
I thought that it was cookies too.
bold huh. That helps. Thanks
DFI Lanparty Venus
Opteron 165 @ 2.8
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
headofmax
