avatar
avatar
Postby JeproX » Sun Mar 27, 2005 6:50 pm
how can i replace the avater with a picture thats in my harddrive? thanks!
ECS915p-a
Intel P4 2.8E oc'd 3.2
SeagateBarracuda Sata 80g
Kingston (2x)512 pc3200
Inno3d 6600 256mb pci-e
Task945tx 450w
JeproX
Postby Sabrewings » Sun Mar 27, 2005 7:14 pm
You have to host it on a website and link to it in your profile. Be careful, as not all websites will allow you to do this.
Sabrewings
Postby JeproX » Sun Mar 27, 2005 7:30 pm
Sabrewings wrote:You have to host it on a website and link to it in your profile. Be careful, as not all websites will allow you to do this.
sorry Sabre but how do i host it? thanks! sorry.. :wink:
ECS915p-a
Task945tx 450w
JeproX
Postby Sabrewings » Sun Mar 27, 2005 7:38 pm
You have to sign up with a site like www.photobucket.com or something.
Sabrewings
Postby JeproX » Sun Mar 27, 2005 7:57 pm
Thanks Sabre! ill try to sign up now... thanks again! :)
ECS915p-a
Task945tx 450w
JeproX
Postby JeproX » Sun Mar 27, 2005 8:14 pm
Sabre i tried to copy and paste the link, then submit.. theres no effect.. no pictures.. :?
ECS915p-a
Task945tx 450w
JeproX
Postby Sabrewings » Sun Mar 27, 2005 8:18 pm
What are you trying to copy and paste in there? Make sure its simply the "http://" one and not one with [IMG] around it or anything.
Sabrewings
Postby JeproX » Sun Mar 27, 2005 8:43 pm
yup! that one.. but theres no changes happened in my profile...
ECS915p-a
Task945tx 450w
JeproX
Postby Sabrewings » Sun Mar 27, 2005 8:49 pm
Is the file a .jpeg or .gif? And does it fit the forum rules?
Sabrewings
Postby JeproX » Sun Mar 27, 2005 10:08 pm
thanks for your patience sabre! got it na! :)
ECS915p-a
Task945tx 450w
JeproX
