unable to view sometimes
Postby danman1012 » Fri Mar 18, 2005 7:20 pm
all the time now, just recently, sometimes when i goto the forums i get a "Permission denied: you do not have access to /forum/viewforum.php and privmsgs.php" this is happening all the time, to fix i have to reopen my browser ( firefox ) and then i can view them for a minute or 2, but then when switching forums it happens again. anyone else have this problem?
danman1012
Postby Toby B. » Fri Mar 18, 2005 8:07 pm
http://www.motherboards.org/forums/view ... hp?t=66770
That is what has already been discussed. Apparently the issue is still ongoing.. 8O
I got a forbidden error the other day.
Toby B.
Postby danman1012 » Fri Mar 18, 2005 8:25 pm
oh ok, sorry about a repost this can be locked or deleted i guess
danman1012
Postby Toby B. » Fri Mar 18, 2005 8:58 pm
danman1012 wrote:oh ok, sorry about a repost this can be locked or deleted i guess
Nope, it will stay here and will remain active til we can get the problem solved.. :wink:
Toby B.
Postby MoboCop » Fri Apr 01, 2005 8:09 am
this is an intermittent problem that will not be solved by us. We must hope that phpbb will fix it in an upcoming version.
MoboCop
Drunken Master
