It is currently Sun Jan 19, 2020 10:18 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: .NET passport pop up
PostPosted: Fri Mar 18, 2005 4:11 am
When I click on the link to go to this thread http://www.motherboards.org/forums/viewtopic.php?t=70289 I get a popup asking me to "Add a .NET Passport to your Windows XP User Account." Is this normal?
Gerald Ford (1913 - 2006)
PostPosted: Fri Mar 18, 2005 4:17 am
Me too 8O 8O 8O
This is NOT normal!
It might be something to do with the Avatar file link.
Code:
http://www.msnusers.com/6jsngi8au4lboie85n8mimmc17/Documents/dancing.gif
Pasting this into an empty browser window will cause a .NET Passport login to popup.
PostPosted: Fri Mar 18, 2005 4:29 am
Having tracked all the posts made by wowitfoth:
http://www.motherboards.org/forums/sear ... =wowitfoth
It does seem to be a profile issue since I get the same popup on all of the posts.
(Why did I not notice before!?! :oops:)
PostPosted: Fri Mar 18, 2005 4:36 am
I think this is something new that wowitfoth added to his profile
PostPosted: Fri Mar 18, 2005 7:11 am
That is correct although I didn't get any pop ups. That's a scary sig, should we be concerned about it?
[/url]
PostPosted: Fri Mar 18, 2005 7:45 am
Drunken Master
I deleted the avatar. I did not get a popup though before I deleted it.
PostPosted: Fri Mar 18, 2005 7:49 am
Thats fixed it. Thank you.
PostPosted: Fri Mar 18, 2005 7:52 am
Thank You
