wierd log in issue
wierd log in issue
Postby Myth » Tue Feb 08, 2005 8:42 pm
Ok... I've had this before but I now have an alternate route that I use to get around in here.
I log in and post some stuff in one forum. If I want to change to another forum now I go either to the bottom and select from the drop down list or I click on "the mother board forum index" at the top. Well, the problem arises if I click on the fourms tab at the very top. I was thinking it would take me back to the index page - wich it did. In the process it no longer recognizes me as being logged in. I still see my screen name at the bottom of the forum index page but the top says that I need to log in. I can't post anything unless I log in again. When I do log in then soon after that I log out I find that I am still logged in (by the bottom of the fourm index). Does this make sense? Not sure if I described it clearly enough. Is it some odd glitch with the fourms tab at the top?
Myth
Postby don'tknowmuch » Tue Feb 08, 2005 8:45 pm
Works OK for me Myth :wink:
don'tknowmuch
Postby Myth » Tue Feb 08, 2005 9:20 pm
You clicked on the tab at the top and stayed logged in?
I have cookies blocked for most stuff... does that cause the problem?
Myth
Postby MoboCop » Wed Feb 09, 2005 8:17 am
Myth wrote:You clicked on the tab at the top and stayed logged in?
I click on tab and stay logged in. You need cookies enabled for the forum to stay logged in.
MoboCop
Drunken Master
