Problem using Firefox to print thread
Postby kaikow » Sat Jan 29, 2005 2:42 pm
Firefox will not print the thread at http://www.motherboards.org/forums/view ... hp?t=67720
The print craps out in the midst of the second article in the thread.
I can save the thread with Firefox, then print with IE.
I guess the thread is either using non-standard HTML or we have encountered a Firefox bug.
If somebody else can confirm the problem, I'll also report this in the Firefox forums.
kaikow
Postby snap355 » Sat Jan 29, 2005 3:10 pm
Looks good to me
Try cleaning out cache, temp internet files, etc
[/url]
snap355
Postby Toby B. » Sat Jan 29, 2005 7:19 pm
The standard phpBB format that is used here is not setup for printing articles. This is a browser issue, not a forum issue...
There are MODs that are design for printing threads, but MoboCop does not use MODs on the forum..
Toby B.
Postby kaikow » Sun Jan 30, 2005 9:39 am
Toby B. wrote:The standard phpBB format that is used here is not setup for printing articles. This is a browser issue, not a forum issue...
so the solution is to save the thread with firefox and then print with ie.
kaikow
Postby Toby B. » Sun Jan 30, 2005 2:41 pm
If that is what works best then yes...
Toby B.
