don't know what to call this
Postby sloopdog 1 » Thu Jan 27, 2005 4:05 pm
why does the topic board stick out past the edge of the the frame(the little black line)?just curious :)
No keyboard detected-Press any key to continue.
sloopdog 1
Postby MoboCop » Thu Jan 27, 2005 4:43 pm
not sure. What browser and resolution are you using?
MoboCop
Drunken Master
Postby snap355 » Thu Jan 27, 2005 5:09 pm
Turn off the magnifing option
[/url]
snap355
Postby Toby B. » Thu Jan 27, 2005 6:57 pm
I just took a look and its fine with IE at 1024 x 768 resolution... :?
Toby B.
Postby CDBurner » Thu Jan 27, 2005 8:00 pm
I've noticed this problem in Opera when there's an image or link in a thread that's longer than my screen is wide (such as this thread on my laptop which only supports 1024x768). Not a big deal, though. :)
CDBurner
Postby Toby B. » Thu Jan 27, 2005 8:23 pm
CDBurner wrote:I've noticed this problem in Opera when there's an image or link in a thread that's longer than my screen is wide (such as this thread on my laptop which only supports 1024x768). Not a big deal, though. :)
True, long links or large images will distort the page. Hence the rules for avatar/sig image sizes..
Toby B.
Postby EmilyB » Fri Jan 28, 2005 12:07 am
:oops: :oops: :oops:
Sorry
EmilyB
Postby Toby B. » Fri Jan 28, 2005 12:17 am
EmilyB wrote::oops: :oops: :oops:
Sorry
Nothing was directed solely at you Emily!!! We still havent heard what sloopdog 1's resolution, etc. was/is set at... :wink:
Toby B.
Postby Guest » Fri Jan 28, 2005 2:39 am
800x600.(easy for me to see) the only forum that has the anomaly is the test forum.Long links elsewhere just make the pages wider.It's not a real problem, just a curiosity.
Guest
Postby sloopdog 1 » Fri Jan 28, 2005 2:47 am
Anonymous wrote:800x600.(easy for me to see) the only forum that has the anomaly is the test forum.Long links elsewhere just make the pages wider.It's not a real problem, just a curiosity.
and I was able to post the previous message with out logging on.and the topic shows no replys.
and why does the quote say Anonymous?
patiently awaitng your answer, sloopdog 1. :)
sloopdog 1
