Cannot Register
Cannot Register
Postby CantRegister » Wed Jan 19, 2005 5:25 am
The link to register isn't working on this PC - can someone post a link to where I can register please?
CantRegister
Postby EmilyB » Wed Jan 19, 2005 5:30 am
Use the following link.
I cant give you any links further along the process, because you need to consent to the age agreement. I hope this helps.
http://www.motherboards.org/forums/prof ... d3316fe28f
EmilyB
Postby Grazer » Wed Jan 19, 2005 9:28 am
That's me registered - thanks!
Grazer
