"Forbidden" error
Postby WGP » Fri Feb 18, 2005 8:00 pm
I just figured out that when one accesses a forum normally, one can click on the topic to see the detail. But when one does a search, one has to click on that tiny icon that looks like a sheet of paper. Oh well...
Warren
WGP
Postby EmilyB » Tue Mar 01, 2005 7:13 am
Ok this is VERY strange!
Im logged in very happily and can post any message in any forums. But when I try and do a "post search" using http://www.motherboards.org/forums/search.php all I get is:
Forbidden
You don't have permission to access /forums/viewtopic.php on this server.
Apache Server at www.motherboards.org Port 80
This has been happening constantly for about an hour now. I can post but I cannot search :?
Ive tried all the usual tricks clearing cache and temp files. Ive even tried logging out and back in but so far nothing helps.
EmilyB
Postby MoboCop » Tue Mar 01, 2005 7:58 am
what search term are you using? Also make sure you use search for all terms.
MoboCop
Drunken Master
Postby EmilyB » Tue Mar 01, 2005 8:08 am
MoboCop wrote:what search term are you using? Also make sure you use search for all terms.
Ok confession time :oops:
I was searching for one of your posts. Sometime ago you wrote a really good list of GMail benefits in the General forum. So I searched for:
- keyword = "Gmail"
- Author = "MoboCop"
- and I restricted the forums search to General
It does find the posts and give me the list of threads (this particular search results in 3 threads) but trying to view a thread from the results gives me the forbidden error.
EmilyB
Postby MoboCop » Tue Mar 01, 2005 8:14 am
http://www.motherboards.org/forums/view ... hp?t=66882
You are right the search works. To get these links to work remove the part of the url that starts with highlight. I believe this is meant to highlight the word on the page.
Turn this
http://www.motherboards.org/forums/view ... ight=gmail
into this
I will see what I can do about fixing it.
MoboCop
Drunken Master
Postby MoboCop » Tue Mar 01, 2005 8:21 am
hmmm, apparently this is a general issue with pbpbb.
http://www.phpbb.com/phpBB/viewtopic.php?t=254847
ok research cut short. Their site just went down.... :cry:
MoboCop
Drunken Master
Previous
