"Forbidden" error
Postby Toby B. » Fri Jan 21, 2005 12:57 am
I leave myself logged in overnight (6-7 hours) and so theres obviously no "activity" from me during that period, then I might get this error when I navigate anywhere
You mean staying here so you have a browser window open for the site for an extended period of inactivity? My internet will cut off after 4 hours of inactivity and usually I have a page open for this site at all times. I have only ever encountered the error once...
I hope that made sense....
Toby B.
Postby EmilyB » Fri Jan 21, 2005 1:02 am
That was perfect sense Toby B. My internet connection has no "time out" thingy so I could leave it on indefinately if need be. But yes you were right with your summary, I meant I leave the browser open on www.motherboards.org/forums and sometimes when I return its a little jittery to get going again, and its only in this situation, that I have seen some errors one of which being this "Forbidden" error.
EmilyB
Postby snap355 » Wed Jan 26, 2005 1:55 pm
I usually leave FF open at home with the mobo website. However when I do use it again, I usually hit the refresh button w/o any errors
[/url]
snap355
Postby MoboCop » Thu Jan 27, 2005 4:43 pm
I still cannot duplicate this error.
MoboCop
Drunken Master
Postby MoboCop » Thu Jan 27, 2005 7:17 pm
ok I saw this error. I believe it has to do with expired session. Exiting browser and reloading should do the trick. I will check over at phpbb and see if this is a common issue.
MoboCop
Drunken Master
Postby snap355 » Thu Jan 27, 2005 7:34 pm
Wow, that's alot of testing to even get to see that error. I couldn't replicate it. :)
[/url]
snap355
Postby EmilyB » Fri Jan 28, 2005 12:09 am
MoboCop wrote:ok I saw this error. I believe it has to do with expired session. Exiting browser and reloading should do the trick. I will check over at phpbb and see if this is a common issue.
Ok that makes total perfect sense. That would indeed explain why and how Ive seen it a few times, i.e. leaving my session open but idle overnight.
EmilyB
Postby Mark H » Thu Feb 10, 2005 5:07 pm
Saw it again today, but just hit "Refresh" and all ok
Mark H
Postby snap355 » Thu Feb 10, 2005 5:09 pm
Still ok on my end
[/url]
snap355
Can't access forum from a search
Postby WGP » Fri Feb 18, 2005 8:40 am
This always fails for me. If I do a search and then try to access a posting, I get Forbidden. You don't have permission...
It does not make any difference if I am using IE or FF. It is not a timeout issue because I just tried to log in.
If I don't do a search, then can access all postings. But I don't want to read thru 865 pages to look for a topic.
Makes it difficult to use if you cannot open anything from a search.
:cry:
Warren
WGP
PreviousNext
