"Forbidden" error
"Forbidden" error
Postby greytrains » Fri Jan 14, 2005 9:31 am
I am getting a "Forbidden" error message every so often when I try to get into any of the forums or the self search. The only way I can get in is to restart IE.
Gerald Ford (1913 - 2006)
greytrains
Postby snap355 » Fri Jan 14, 2005 10:16 am
Use firefox :D
[/url]
snap355
Re: "Forbidden" error
Postby KURIAKI » Fri Jan 14, 2005 11:41 am
dhuber wrote:I am getting a "Forbidden" error message
Me too.
More than 100,000 BIOS strings in my database just now!
Saludos desde Cancun, Mexico
KURIAKI
KURIAKI
Postby greytrains » Fri Jan 14, 2005 12:26 pm
snap355 wrote:Use firefox :D
Can't this is a work computer
greytrains
Postby snap355 » Fri Jan 14, 2005 6:08 pm
Tested it with IE 6 and all the latest patches, no probs so far
[/url]
snap355
Postby MoboCop » Fri Jan 14, 2005 11:24 pm
can you supply a link?
MoboCop
Drunken Master
Postby Mark H » Thu Jan 20, 2005 3:41 pm
I get it also:
Forbidden
You don't have permission to access /forums/viewtopic.php on this server.
Apache Server at www.motherboards.org Port 80
I also noticed, when I clicked on this topic, I briefly saw the "Forbidden" page.
Mark H
Postby Toby B. » Thu Jan 20, 2005 8:03 pm
I have recieved this error once and that has been it since..
Forbidden
Toby B.
Postby Myth » Fri Jan 21, 2005 12:16 am
I get it to every now and then. It seems to have started about a week ago. The only way around it is to shut down IE and restart it. Then, everything works properly.
Myth
Postby EmilyB » Fri Jan 21, 2005 12:41 am
Ive never mentioned it before, because the ratio between time spent here and getting that error for me personally is less than 1 in every 1000 and so it was never a problem, I even managed to "fix" with a simple browser refresh. But I do remember seeing it before, just a couple of times.
I hate pretending to be techie (because we all know Im not) but for me it seems to happen with a "stale" login i.e. if for example I leave myself logged in overnight (6-7 hours) and so theres obviously no "activity" from me during that period, then I might get this error when I navigate anywhere.
EmilyB
