Weird Firefox Issue
Postby Hardware Junkie » Fri Jan 07, 2005 7:43 pm
Ghen wrote:I've a gig of memory. It better not slow down.
So do I.
My settings appear to be already at those mentioned in the post...
Postby HollowPoint69 » Fri Jan 07, 2005 9:27 pm
This EXACT things happens to me. I was considering posting about in the TS forum a while ago. It starts using 90-99% of the CPU, and my entire system basically locks up, unless I close it. It's REALLY wacked up.
HollowPoint69
Postby snap355 » Sat Jan 08, 2005 5:44 am
Maybe it's something else that's holding firefox up. Mines stays at 0-1 %
[/url]
snap355
Postby Hardware Junkie » Sat Jan 08, 2005 8:24 am
Postby Hardware Junkie » Sat Jan 08, 2005 8:31 am
Postby colinJohn » Sat Jan 08, 2005 8:35 am
How did you know you had a mem problem?
You sure the cpu usage is not caused by Folding?
fyi - I've got 3 tabs open - ff mem usage is 34,232K.
"It's the best that there is"
colinJohn
Postby Hardware Junkie » Sat Jan 08, 2005 8:40 am
It happens when ever I go through alot of tabs and go to sites with flash.
Its exactly as they are describing...
I am going to try the fix mentioned at the Mozilla forums and see how it works.
I'll post in a few days
Postby Oylpann » Mon Jan 10, 2005 1:25 am
Just ran into that same issue for the first time tonight with it. Any luck HWJ?
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
Oylpann
Postby Black Wolf » Mon Jan 10, 2005 3:42 am
I have never had a problem with Firfox, it always uses around 40MB of memory and stays in the 1-2% CPU ussage.
Black Wolf
Postby Hardware Junkie » Mon Jan 10, 2005 10:48 am
So far with changing the amount of memory being used it works better. Flash objects seem to be the main problem.
Firefox has problems with 12-15 tabs and a flash page being used...
PreviousNext
