High CPU Utilization - Crucial Ad
Postby pa3lsvt » Mon Jan 03, 2005 4:06 pm
Anyone else notice high CPU utilization when browswing the forums here? I'm running at 50 - 75% with just one tab open in Firefox. Unchecking Play and/or Loop when I right click the ad doesn't do anything to lower the CPU demand. Going to any other website fixes the issue.
It interferes with running just about anything else, but most noticably my PCTV Pro (software compression) TV capture card - I lose synch with video and audio b/c the Crucial ad hogs all my CPU cycles.
Seeing as I have an XP2500 OC'ed to 3200, and a 6600GT AGP vid card, with 512 MB DDR400, I can't be the only person that notices this - it must choke lesser rigs; otherwise I must have something set wrong to allow the Flash ad to get so much CPU time.
pa3lsvt
Postby Falklian » Mon Jan 03, 2005 4:16 pm
Mine isn't doing that at all, shows Firefox using between 0 and 2 percent of the CPU. My system also isn't all that great, P4 2.4ghz GeForce 4 TI 4400, a gig of PC2100 RAM. Maybe a problem with Firefox and the Flash plugin. You have the latest versions of both?
Falklian
Postby MoboCop » Mon Jan 03, 2005 4:32 pm
I dont have this problem.
You might want to test it a bit more.
Try right clicking ad and unchecking play. See if that changes it.
I would also check for spyware and/or viruses.
MoboCop
Drunken Master
Postby sloopdog 1 » Mon Jan 03, 2005 4:33 pm
I remember a couple of months ago someone else had a similar problem with an add here because of all the resources it used.can't find the old thread though.
No keyboard detected-Press any key to continue.
sloopdog 1
Postby Sabrewings » Mon Jan 03, 2005 7:24 pm
Running at 3% with this page open and the ad showing. Not sure what is happening to yours. Try uninstalling and reinstalling.
Sabrewings
Postby Ryn » Tue Jan 04, 2005 12:55 am
sometimes it does happen to me too, firefox is eating arround 30-50% on cpu utilization
Ryn
Postby CDBurner » Tue Jan 04, 2005 10:33 pm
It's happening to me, too (right now in fact); Opera is using between 50 and 99% CPU time (Celeron 1200 laptop) when browsing the motherboards.org forums. It doesn't always happen; my guess is that it's related to the Crucial ad, like others have said. I tried updating the Flash plugin, but that didn't seem to help much if at all.
CDBurner
Postby MoboCop » Wed Jan 05, 2005 1:18 am
try right clicking on the ad and unchecking play and see if that makes a difference?
Using IE I have never seen such a thing.
MoboCop
Drunken Master
Postby sloopdog 1 » Wed Jan 05, 2005 2:49 am
my cpu useage stays at 0 untill I click on the crucial ad.Then it goes up to 35%,and stays there untill I close mobo.That site uses a lot.
sloopdog 1
Postby snap355 » Wed Jan 05, 2005 6:45 am
sloopdog 1 wrote:my cpu useage stays at 0 untill I click on the crucial ad.Then it goes up to 35%,and stays there untill I close mobo.That site uses a lot.
You're right about that
[/url]
snap355
