Team Folding Stats (mb.org site) Not Updating
Postby Wookie8662 » Sun Jan 02, 2005 9:15 pm
The team/member stats havent updated at all during this new year (2005),
http://www.motherboards.org/folding/team_stats.html
If you look, all the milestones are as of 12-31-2004.
Nothing new has been updated since then.
Maybe something in the coding, or database that needs a slight tweak?
The current team points total, and number of WU completed are correct.
Thanks in advance.
(edit to add url link)
Wookie8662
Postby MoboCop » Mon Jan 03, 2005 4:04 pm
stats were updating. I just had buggy code trying to display them.
Code has been fixed!
MoboCop
Drunken Master
