no rep;y notification e-mails
Postby tommie j » Fri Dec 10, 2004 8:52 am
ive noticed latelty that im not receiving the notification email when i reply to a thread. i checked profile ,the notification box is enabled so im not sure what it could be. i checked the junk box and deleted folders in outlook as well. any thoughts? maybe i'll get this one.
tommie j :D
I bailed, moved to puerto rico ,lifes too short!
tommie j
Postby snap355 » Fri Dec 10, 2004 9:22 am
It could be that the website is not functioning properly to send you a notification email as oppose to your email having troubles. It could also be your spam software blocking it
[/url]
snap355
Postby S33K3R » Fri Dec 10, 2004 9:49 am
you realy have to take a look at the forum names as it will tell you were to post. you realy should have posted this in the web site problems forum.
surely a mod can move it there
S33K3R
Postby snap355 » Fri Dec 10, 2004 11:17 am
Are you having a problem with this website in particular?
[/url]
snap355
Postby tommie j » Fri Dec 10, 2004 11:36 am
yeah, just this web site.i used to get the notifications. now that i think of it this may have started with sp2 install..not positive though.
tommie j
Postby tedybear » Fri Dec 10, 2004 2:11 pm
I've been having the same problem for the last few months...before Sp2 was installed...I'm on several forums. This is the only one that can't get the notifi's to me..
Might want to drop a note over in the 'error's section....
S-
tedybear
Postby Sabrewings » Fri Dec 10, 2004 3:10 pm
I'll move this down. I believe there have already been a few threads on the issue, and Mobocop is seeking to resolve it.
Edit: Take a look at this.
http://www.motherboards.org/forums/view ... 9&start=50
Sabrewings
Postby MoboCop » Fri Dec 10, 2004 3:14 pm
yes this is an outstanding issue since we moved to a new server. I believe it is related to apache 2 or php5 and the phpbb forum software.
I cannot resolve the issue though. I am hoping the next version of the software will take care of it, otherwise I am not sure how to resolve it. It is intermittent. It works fine for many users.
MoboCop
Drunken Master
Postby J.C.GARCIA » Fri Dec 10, 2004 3:43 pm
well i was just about to change my email again seeing a post further down where mc says he had resolved the issue . well it will eventually iron itself out . by the way using sp1 here with xp home .
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby tedybear » Fri Dec 10, 2004 5:59 pm
SP2 in use here (but this problem started a couple of months before I did the upgrade)
I'm on a few other forums, and have no issues with getting notif's back...strange..
S-
Ohh...did the Toss the cookies and cleared the cache several times...
tedybear
