It is currently Fri Feb 22, 2019 9:08 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Where's the nav bar??
PostPosted: Thu Aug 01, 2002 9:56 pm
what happened to the nav bar that was at the top of the home page? is this another update? i now have to scroll to the bottom of the page and use the links there to navigate to the forums. i had problems with the nav bar before, but worked around it....now it's gone. i'm using IE 4.7, is this problem specific to my browser? anyone else having this problem?
PostPosted: Fri Aug 02, 2002 8:50 pm
Drunken Master
interesting. I changed the nav bar because people did not seem to like it jumping around the screen. So you cannot see the new one?
Is there anyway for you to go to a 5.x browser?
PostPosted: Fri Aug 02, 2002 8:59 pm
Shows up for me under 6 and 5.5 SP1
PostPosted: Fri Aug 02, 2002 9:31 pm
no nav bar shows at all. i could upgrade to a newer version of IE i guess, but i was hoping i wouldn't have to. (just stubborn i guess) oh well, guess it's about time to move on to a newer version. thanks....i thought iwas loosing it there for awhile. only half a mind left to loose anyway. :lol:
PostPosted: Fri Aug 02, 2002 10:30 pm
When I went to the main page earlier this evening I noticed the Navigation bar took about 20 seconds or so to come up. I also noticed that On the main page I am not logged in but it shows me as logged on at the bottom of the page. Maybe just another glitch on my end.
Toby
Compaq-Fu Master
PostPosted: Tue Aug 06, 2002 9:00 am
Drunken Master
ok I changed the damn nav bar again. This one should load fast and should be fine in 99% of browsers including 4.x versions. 3.x you better upgrade or find another motherboard site.
PostPosted: Tue Aug 06, 2002 10:13 am
it's back!! thanks! hope you didn't loose to much sleep working on this one.
seems to work great for me........ :D
