It is currently Thu Jan 17, 2019 3:08 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Wed Jul 31, 2002 11:31 pm
I also use a diff forum for other stuff that is the same as this one. Meny of my friends use my puter as it is the only good puter in the park. How do i set up diff users without having it auto login as dademurphy31. so diff pepole can use the same puter for fourms?
Listen to Montag
PostPosted: Thu Aug 01, 2002 10:35 am
Drunken Master
I have not tested this but it should be simple.
Log out.
Log back in. DO NOT check log me in automatically.
at this point whenever you return to the site you should be able to login with any valid account.
PostPosted: Thu Aug 01, 2002 11:26 am
And if you didn't want it logging in to any website automatically, you could disable your cookies.
-Jon-
note from mobocop: DO NOT TURN OFF YOUR COOKIES AND EXPECT THE FORUMS TO WORK. THEY WILL NOT.
