Time is not set correctly
Postby CDBurner » Fri Feb 06, 2004 5:40 pm
The clock on the forum seems to be set incorrectly. I have my timezone set correctly in the preferences (GMT-7 because I am in the Mountain Time Zone), but the time still isn't right. I made a post a few minutes ago, and the time stamp said 6:35PM, but the actual time was approximately 12:50PM.
CDBurner
Postby MoboCop » Fri Feb 06, 2004 7:04 pm
yep. Time is one issue that PHPbb just cannot seem to get right. I will be upgrading to lates version soon. Hopefully they will have gotten it right.
MoboCop
Drunken Master
Postby CDBurner » Fri Feb 06, 2004 7:25 pm
Ah, I see. Thanks for your response!
CDBurner
Postby Toby B. » Sat Feb 07, 2004 2:03 am
dumb question but is the clock on the server set to the correct time? I have used phpbb 2.0.0 through 2.0.6 and have not had a problem with the time showing this far off.
Toby B.
