Newsletter Link
Newsletter Link
Postby CDBurner » Sat Jan 31, 2004 6:27 am
When I clicked on the "Newsletter" link on the home page, I got this error:
Code: Select all
Warning: main(common2.inc): failed to open stream: No such file or directory in /home/virtual/site1/fst/var/www/html/newsletter.html on line 3
Fatal error: main(): Failed opening required 'common2.inc' (include_path='.:/home/virtual/site1/fst/var/www/html/includes') in /home/virtual/site1/fst/var/www/html/newsletter.html on line 3
CDBurner
Postby Toby B. » Mon Feb 02, 2004 2:00 pm
Just saw this, I have sent off an email to let MoboCop about the error.
Toby B.
Postby MoboCop » Mon Feb 02, 2004 5:08 pm
Thanks. This has been fixed.
MoboCop
Drunken Master
Postby CDBurner » Mon Feb 02, 2004 5:22 pm
Thanks, I just checked the link, and it seems to be working. However, I just tried to sign up for "Daily News Blast" and "Weekly Newsletter", and I got this error when I clicked "submit".
Code: Select all
Warning: main(common2.inc): failed to open stream: No such file or directory in /home/virtual/site1/fst/var/www/html/confirm.html on line 3
Fatal error: main(): Failed opening required 'common2.inc' (include_path='.:/home/virtual/site1/fst/var/www/html/includes') in /home/virtual/site1/fst/var/www/html/confirm.html on line 3
CDBurner
Postby MoboCop » Mon Feb 02, 2004 5:56 pm
ok squashed that one too. Thanks.
MoboCop
Drunken Master
Postby CDBurner » Mon Feb 02, 2004 6:33 pm
Thanks for fixing it! :D
CDBurner
