how to view my old post?
Postby goleagt » Mon Dec 22, 2003 2:18 am
Hi, i was wondering how can i access or veiw all my post that i have posted. Reason i am asking need to review some of the infomation that was replyed to be since i miss placed my printed copys. Thank you
goleagt
Postby undying fenix » Mon Dec 22, 2003 3:04 am
Go to search and type your name in as the author. It should list all the posts you have made.
Hold that thought.
undying fenix
Postby son0rous » Mon Dec 22, 2003 3:05 am
^^^^^^click on the profile button just above the arrows on the left, it will show your profile, then click "find all posts..."
son0rous
Postby undying fenix » Mon Dec 22, 2003 3:06 am
Ehhh same thing.
Hold that thought.
undying fenix
Postby peta_byte » Mon Dec 22, 2003 3:37 am
yeah that works but you also have the option of clicking on the "View your posts" link on the upper right side of the main forum page.. under "View posts since last visit" link.. which is the best way to surf a forum.
peta_byte
Postby Tulatin » Mon Dec 22, 2003 12:02 pm
just be wary that if you haven't been here for something like a year and a half, your original posts may be gone...
Tulatin
