TimeZone option? needs up date
Postby joe_devore » Fri Dec 05, 2003 11:04 pm
I found a problem with the Time zone option
Sat Dec 06, 2003 1:26 am
The above date stamp was taken kust a few minutes go.
My Date/Time is:
Friday, December 5, 2003; 8:05:52 PM
I need Some Help re-setting my Time Zone Option.
I am used to setting off the Prime merdian Time.
My Time Zone is:
(-5:00 Hours, EST, Eastern Standard Time)
I live in Dover, New Hampshire.
GMT?
Did that stand for General Mountain time?
What Should I set The Time Zone Option to?
joe_devore
Postby Demosthenes » Sat Dec 06, 2003 12:51 am
atleast in winxp it has the option for "(-5:00 Hours, EST, Eastern Standard Time)" in the drop down menu.. so i suggest you select that...
that is your time zone afterall :) dunno about other versions of windows though..
WinXP Pro
1.9ghz AMD Athlon XP (barton core) OCed to 2.25ghz
Volcano 9
Abit NF7 rev. 2
512mb Apacer Infineon DDR3200 in dual channel mode
Gigabyte 5900xt
4x Aopen DVD burner
400 watt PSU
120Gig 7200rpm Maxtor
Demosthenes
Re: TimeZone option? needs up date
Postby ssamurai26 » Sat Dec 06, 2003 3:37 am
joe_devore wrote:I found a problem with the Time zone option
[snip]
GMT?
If you are talking about thiw website, then this is a known and common problem, with lots of posts addressing it. The time feature is off.
And GMT stands for Greenwich Mean time.
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
ssamurai26
Postby joe_devore » Sun Dec 07, 2003 10:19 pm
? Greenwich Mean time ?
Is that not the zero hour off which the prime merdian is mirrored
I am across the street using a friend Imac, Because I don't Own my own PC yet.
joe_devore
