Board Style Unchageable.
Postby Tulatin » Thu Oct 30, 2003 11:04 pm
After seeing subSilver for so long, i wanted a bit of a change, so i thought i'd try desertstorm. Well, it does nothing. I switch it over, hit apply - nothing. So i figure i'll try again - so i go back, and it's set to desertstorm. But i don't see anything. I've also tried logging out and back in with no avail. Any ideas (also cleared files)
Tulatin
Postby ssamurai26 » Fri Oct 31, 2003 12:54 am
Same problem here.
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
ssamurai26
Postby Toby B. » Fri Oct 31, 2003 1:38 am
That particular template has been deleted long ago. No new ones have been added (obviously)...
hmm, try putting a poll in the recommendations, or Feature Requests. If you arent sure where to get the list of current templates availible let me know and I will provide it for you.
If there is enough support for a new template (or maybe two) then maybe MoboCop will get one added.
Thanks
Toby B.
Postby Tulatin » Fri Oct 31, 2003 4:51 pm
I've seen a few templates out there - like the black one, medevil... where do yo uget these?
Tulatin
Postby Toby B. » Sat Nov 01, 2003 12:10 am
Toby B.
Postby Tulatin » Sat Nov 01, 2003 12:17 am
Thanks for the list. I'm particularly fond of aallix silver. I suppose the method to getting one of these implemented is feature requests, start a poll?
Tulatin
Postby Toby B. » Sat Nov 01, 2003 12:38 am
Yup, an informal poll though.
Poll question should be something to the effect of: Should we have more template options? yes or no.
Then provide that link. Whatever shows the most popularity is the winner. I will let MoboCop know of the poll once started...
Toby B.
Postby Tulatin » Sat Nov 01, 2003 12:39 am
i'll start that up tomorrow. Right now i've got about 3 minutes left in my day... :roll:
Tulatin
Postby MoboCop » Thu Nov 06, 2003 5:28 pm
not going to happen. Themes are cool but become a problem when you have modded phpbb. I am not about to maintain multiple themes and the associated code. This was why desert storm was removed (besides the fact it was ugly as hell).
MoboCop
Drunken Master
Postby Tulatin » Thu Nov 06, 2003 5:29 pm
Ah. That makes sense. So, like emoticons, there's no point in adding them because you have to screw with the software.
Tulatin
