problems trying to post replies
Postby darrellw » Thu Oct 23, 2003 4:19 am
a number of times when i have wanted to post a reply to a topic i am redirected back to the forum page listing
eg
http://motherboards.org/forums/viewtopi ... 527e78364e
happened many times on other topics
usually on the second attempt i am able to post a reply
cheers
darrellw
darrellw
Postby peta_byte » Thu Oct 23, 2003 9:38 am
what browser are you using ? IE ? are you all patched ?
if it's IE.. can you do a... help/about internet explorer and post what it says ?
I've never seen any problem here like that..
peta_byte
Postby Tolemac » Sun Oct 26, 2003 4:10 am
You're the first one to come up with this problem Darrell. As peta asked, what browser are you using?
Tolemac
Postby Toby B. » Sun Oct 26, 2003 4:18 am
Tried fixing the problem by clearing "cookies" and temp files then attempting to reply???
Toby B.
Postby darrellw » Sun Oct 26, 2003 1:22 pm
cheers for the replies using IE6 all patched up to last week anyway (there are that many patches at the moment).
just deleted cookies, not sure where my temp folder is though.
will have a play and report back
cheers
darrellw
darrellw
Postby Toby B. » Sun Oct 26, 2003 7:52 pm
Under Internet Properties (or Options) in the Control Panel. You will have an option to set your ho,e page, Temporary Internet Files ->Delete Cookies - Delete Files {i.e. these are the temp files} - and Settings.
Toby B.
Postby peta_byte » Sun Oct 26, 2003 11:56 pm
you can also try an IE repair.. or get opera or mozilla.. less exploits are reported with those anyway.
peta_byte
