login
login
Postby scifiguy1 » Mon Sep 08, 2003 3:28 pm
hi all , just registered and wanted to use the mobocop feature to id a mobo but came back saying i needed to login but am already logged in , error on my part ??? please let me know Dick
p.s. i am looking for a program to run on another pc to id the mobo on that one that is not connected to the internet, any help in that direction would be helpful!!!!!!
scifiguy1
Postby evasive » Mon Sep 08, 2003 4:00 pm
empty internet cache and allow cookies.
Postby Toby B. » Mon Dec 08, 2003 5:17 pm
The BIOS wizzard link in the following thread is what you are looking for. Just be aware that if you are trying to use this on an OEM system the results are not satisfactory.
save to a floppy disk and then load the program on the other PC.
http://www.motherboards.org/forums/viewtopic.php?t=250
Toby B.
