Users on line
Users on line
Postby jronald » Wed Sep 03, 2003 9:21 pm
This isnt that big of a problem but while using Mozilla my handle never shows up on the botom of the page? (users on line)
Wonder why?
Ron
My son carries in his childhood, the wonders I have sought my lifetime to find, and squandered fortunes to posses
jronald
Postby Tulatin » Wed Sep 03, 2003 9:34 pm
Likely it doesn't accept the cookee properly, so your login cannot be tracked...
Tulatin
Postby jronald » Wed Sep 03, 2003 10:42 pm
changed the settings, cookies no longer blocked, still dont see my name in lights...im heart broken.
ron
ps can you tell im typing with one hand
jronald
Postby son0rous » Wed Sep 03, 2003 10:44 pm
does it work normal with other browsers?
your not exactly in realtime so nope
son0rous
Postby Toby B. » Tue Sep 09, 2003 1:24 am
If this problem occurs in other browsers as well then check in your profile for "hide online status" or something to that effect. That box should be left blank if you want to be seen as online.
Toby B.
Postby jronald » Tue Sep 16, 2003 9:56 pm
I think I tracked it to ZoneAlarm
Ron
jronald
