Mobot
Postby MoboCop » Mon Sep 01, 2003 5:53 pm
MOBOT is an interesting issue. Without going into too much detail, the current backend system for MOBOT was designed by someone else and I do not have anyway to modify that current system.
The only solution to the current problem is for me to redesign the entire system and start data entry from scratch.
Not sure if this is going to happen based on past traffic for MOBOT.
MoboCop
Drunken Master
Postby Tulatin » Mon Sep 01, 2003 5:54 pm
Is there any way of contacing this previous author to find out his methods of madness?
Tulatin
Postby Toby B. » Tue Sep 02, 2003 3:40 am
Tulatin wrote:Is there any way of contacing this previous author to find out his methods of madness?
MoboCop can most likely contact the person if their contct info is still valid.
As far as the staus of MOBOT, it is being looked into. This is a large endeavor and will take time......
Toby B.
Postby Tulatin » Tue Sep 02, 2003 5:05 pm
I may be able to do it one day - mayhap like a master list of P4 boards i can do (no guarentees)
Tulatin
Previous
