Signature Problem
Signature Problem
Postby Felix Jongleur » Fri Jul 18, 2003 7:07 pm
I made a ????.gif pic that I would like as my signature, the only problem is that I don't see how to do it! Should I get one of those free websites and upload the pic there then link it in the sig?
Thanks in advance!
-Felix
Abit AV8 BIOS.26
A64 3000+ Winchester @ 2.2ghz
HyperX 2x512mb Pc-3200 2.5-3-3-8 @ 250mhz
eVGA 6800GT @ 374/1.03ghz
40gb WD400 IDE
80gb WD80 SATA
Audigy 2 OEM
WinXP Pro SP2
Enermax EG465AX-VE 460w
Felix Jongleur
Postby Toby B. » Sat Jul 19, 2003 3:03 am
MoboCop wrote:Greetings all.
Here are the guidlines for images in sig files. DONT.
Instead go to your profile (look to the left of the login link above) and scroll all the way down to avatars. You may link to an image (100wide x 200 high max) or select from a multitude of avatars (over 600) by clicking on the gallery button.
Please just use text only in your sig file.
Thanks.
Toby B.
