why cant i post in recommendations forum?
Postby ***** » Mon Jul 07, 2003 7:32 am
just recently everytime i try to post in the "recommendations" forum i get an "invalid session" msg. It's weird 'cos its not happenning elsewhere.
I can post in other forums on mobo.org. This is happening from a very old maching of mine using 98se. IE5.
What seems to be the problem?
cheers,
ft
Postby evasive » Mon Jul 07, 2003 5:31 pm
time to clear out the temporary internet files. invalid_session errors have been creeping in for some time, this is what fixed it for me.
AOL is no longer supported on the forum, if you happen to have some leftovers, kill them off.
Postby ***** » Tue Jul 08, 2003 12:20 am
ah...excellent. Cleared temp net files. thankyou evasive
cheers,
ft
