errors on the P4 mobo rankings page
Postby srjrol » Tue Jun 24, 2003 11:24 pm
If you look at this page the 3rd one from the top you will see that the chipset mentioned is the 865p when you click the link it is actually a mobo using the 875p chipset. ... -rank.html
This is my first post =). Hope it helps.
Postby MoboCop » Wed Jun 25, 2003 3:23 pm
Thanks. I have fixed this.
Drunken Master
