Postby stormshaker » Tue Jun 24, 2003 8:27 am
If I select the Create a New Case on the MoboCop page, at tells me I have to log in.
When I click login, it prompts me to log into the forums - i.e. I supply my user/pass and on submit I'm taken to the forums... NOT to Mobocop!
Whenver I try to go back - it's always the same! What's going on?
Postby Toby B. » Sun Jun 29, 2003 2:13 am
If you are hitting the browser's "back" button, then that whats wrong. You need to (when prompted to) log in/register then to get back to the mobocop page use the link at the top of the page and then select mobocop from the menu.: forums. Free tech support, motherboard ID, and more.
Toby B.
Postby evasive » Mon Jul 07, 2003 5:34 pm
Clear your IE temp files out for starters. usually this will fix it
