It is currently Sun Sep 23, 2018 1:16 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: Offsite Avatar
PostPosted: Sat Jun 14, 2003 5:19 pm
Why can't I link to offsite avatar? Image is well under 80x80 pixels.When
I type the url and submit all I get is an X...WTF?
Cat:The other white meat.
PostPosted: Sat Jun 14, 2003 9:56 pm
The Url must be incorrect. right click the image for properties, highlight that, copy, and paste into offsite avatar thing. After all - mine works and it's ofsite...
PostPosted: Sat Jun 14, 2003 11:42 pm
it should look something like this (without the quote marks):
"http://www.yoursite.com/myimage.jpg"
PostPosted: Sun Jun 15, 2003 12:36 am
The site that you have or are getting the avatar from needs to allow "hot-linking".
A lot of free webhosts do NOT allow "hot-linking". These would include tripod.com, 0catch.com, as well as others. Also a word of advice - ask the site owner/webmaster for permission before robbing a site of bandwidth.....
Compaq-Fu Master
PostPosted: Sun Jun 15, 2003 7:27 am
The url is correct.It's an avatar from another board I belong to.The hotlink
suggestion I think is probably the reason.Thanks.
PostPosted: Sun Jun 15, 2003 7:50 am
AAAAH,the hell with it....Ive wasted enough f*****g time already.
PostPosted: Mon Jun 16, 2003 10:46 am
Cortez - email me it - i'l post it on angelfire, and throw it across for you to load up.
PostPosted: Fri Jul 18, 2003 7:08 pm
Is it possible to do the same with a signature?
Abit AV8 BIOS.26
A64 3000+ Winchester @ 2.2ghz
HyperX 2x512mb Pc-3200 2.5-3-3-8 @ 250mhz
eVGA 6800GT @ 374/1.03ghz
40gb WD400 IDE
80gb WD80 SATA
Audigy 2 OEM
WinXP Pro SP2
Enermax EG465AX-VE 460w
PostPosted: Fri Jul 18, 2003 7:10 pm
You mean an image in it from offsite? While possible, the laws of the land forbid it - no images in signatures, text only please.
PostPosted: Fri Jul 18, 2003 7:11 pm
It took me 2 hours to make it...
-Felix
Abit AV8 BIOS.26
40gb WD400 IDE
80gb WD80 SATA
Audigy 2 OEM
WinXP Pro SP2
