Typo in the Mobo ratings...
Postby Masterpiece » Fri Jun 13, 2003 9:06 pm
I was just checking out some AMD mobo ratings after I read the review for the Soltek SL-75FRN-L and noticed this mobo should be second ranked on the list instead of 7th according to the rating on the review. Looks like someone gave it a 22 on features in the ratings instead of the 32 it got on the review. Just thought I'd point that out...
Nice site by the way :D
AMD Mobo rankings : http://www.motherboards.org/rank/AMD/to ... -rank.html
Soltek SL-75FRN-L Review: http://www.motherboards.org/articlesd/m ... 244_1.html
/server irc.tnt.cx /j #tnt Stop Whining.
Masterpiece
Postby some_random_guy » Fri Jun 13, 2003 10:27 pm
I went to go look at that and noticed that NONE of the scores from reviews were the same as their respective rankings :!: :?:
Did you know that 64% of all statistics are made up on the spot?
If quizes are quizzical, then what are tests?
If electricity comes from electrons, does morality come from morons?
save the drama for your mama
some_random_guy
Postby effika » Sat Jun 14, 2003 4:16 am
Each time they get a new mobo in for review, they redo all the rankings to keep a relative rank of everything. So a lot of the scores may not match up. Don't worry! :)
You should fold.
effika
Postby Masterpiece » Mon Jun 16, 2003 8:57 pm
Indeed.
Now that that has been explained I'll be sure to check out both the rankings and the review scores from now on. Thanks for the replies.
Masterpiece
