It is currently Mon Aug 20, 2018 5:02 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: BBcode
PostPosted: Sat Jun 29, 2002 11:53 am
ok i am sure its me and i am just doing somthing wrong but i used to be able to create a link for pages like http://www.newegg.com without showing newegg.com but for some reason those types of links are not working then end up like this newegg so whats wrong? and was there not a guide on the old forum about how to use all the different codes? where is that now?
PostPosted: Sat Jun 29, 2002 9:57 pm
Did you try clicking on the BBCodehighlighted on the side under options.
If that doesn't work try this link :)
http://www.motherboards.org/forums/faq.php?mode=bbcode
1. If you don't know ask-
2. If you do know tell -
3. If you think you know refer to 1.
PostPosted: Sat Jun 29, 2002 9:58 pm
It worked for me. Must be a mistake in your html.
PostPosted: Sat Jun 29, 2002 10:19 pm
i see my mistake now thanks :)
