Fatal error
Fatal error
Postby Tau » Sun Apr 27, 2003 7:33 pm
When using the back button i am getting this error message appearing.
Dont know if its a site problem or a server problem.
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 184320 bytes) in /home/virtual/site1/fst/var/www/html/forums/index.php on line 391
Tau.
"Learn from other people's mistakes, it's quicker."
Tau
Postby len444 » Mon Apr 28, 2003 6:07 pm
and i received this error yesterday. i generally don't post the errors, but then i figured i'd let you know that it's not your system:
"Host '207.44.172.21' is blocked because of many connection errors. Unblock with 'mysqladmin flush-hosts'
notice: Could Not Connect to the Database. Please try again in a few moments. Motherboards.org
phpBB : Critical Error
len444
Postby son0rous » Mon Apr 28, 2003 10:40 pm
i recieved the same message as len444, thought it was just me tho. blocked me out for about 24h
son0rous
Postby Deathsythe » Mon Apr 28, 2003 10:45 pm
me too
Deathsythe
Postby Toby B. » Mon Apr 28, 2003 10:51 pm
Len444 wrote:and i received this error yesterday. i generally don't post the errors, but then i figured i'd let you know that it's not your system:
typical error related to too many connections to the sql server....
Toby B.
Postby Deathsythe » Mon Apr 28, 2003 10:55 pm
If thats the case how did the boards handle that 25000 people in December. Just curious
Deathsythe
Postby Toby B. » Mon Apr 28, 2003 11:39 pm
good question. :? I honestly dont know...
Toby B.
Postby Tau » Tue Apr 29, 2003 4:21 am
Glad I wasnt the only one then.
Seems to have fixed itself now. :D
Was getting desperate for my fix of Motherboards 8O
Tau.
Tau
Postby Toby B. » Tue Apr 29, 2003 4:40 am
Tau, the original error you recieved that started this thread I am unsure what causes that one. I have recieved it myself a few times......
The error Len444 posted was related to the sql server.
Toby B.
Postby Valour » Tue Apr 29, 2003 10:35 am
Deathsythe wrote:If thats the case how did the boards handle that 25000 people in December. Just curious
That number was ten times the previous number and many times the average number, and I think it was some sort of screw-up or anomaly.
-Jem
Valour
