invalid_session errors caused by AOL software.
Postby len444 » Fri Sep 19, 2003 10:19 pm
getting invalid session errors- no AOL here. i've gotten this w/ dial up w/ win 2k and IE 6.1, and in mandrake linux w/ mozilla (not sure which version).
len444
Postby evasive » Sat Sep 20, 2003 1:51 am
If page loads too slow the session may time out. Tried with same system on a faster link?
Postby len444 » Sat Sep 20, 2003 9:41 am
i mainly use dsl, but have been experimenting w/ dial up due to research into setting up FAH to run w/ dial up config. due to my modem being HSP micromodem, it isn't used w linux. this has occurred during the past couple of days.
len444
Postby Nomad69 » Sat Jan 31, 2004 7:06 am
Comcast broadband/Netscape 7.1 get errors around 1 to 130 am EST. AOL never had it and never will. I'll use smoke signals first. Getting it in SuSE with Opera also. I don't use IE because of pop ups and security holes.
ABIT Fatal1ty FP-IN9
C2D 6400
GateWatch-Aerocool
XMS PC800 2gb
2 X 250gb Seagate /Raid0
1900XT
Audigy X-Fi
Nomad69
Postby evasive » Sat Jan 31, 2004 7:26 am
That is most likely a server problem on this side. Mobocop has hired external help to get it solved.
Postby Pette Broad » Mon Feb 02, 2004 1:44 pm
I seem to get these invalid_sessions when the post count on a topic reaches double figures. I'm having to start a new topic in order to post. Odd :(
EDIT Obviously this post is well into double figures so it doesn't happen all the time
Pete
Pette Broad
Postby Toby B. » Mon Feb 02, 2004 1:56 pm
You are using an external browser (i.e. not the AOL browser), correct?
Toby B.
Postby Pette Broad » Mon Feb 02, 2004 6:49 pm
Yes, I use IE (6.0.2600) from within AOL, could that be the problem?
Pete
Pette Broad
Postby MoboCop » Tue Feb 17, 2004 12:40 am
well I would venture that there are situtions with PHP (the scripting language used by these forums) has issues with sessions.
I will be upgrading to the latest version of phpbb soon (we are already running latest version of php itself). Hopefully this will correct the invalid session problems once and for all (they were introduced on the version we are using now or the one just prior to it, cannot recall).
MoboCop
Drunken Master
Postby evasive » Tue Feb 17, 2004 11:04 am
invalid_sessions appeared with 2.04. That's the reason wimsbios is already running 2.06
PreviousNext
