invalid_session errors caused by AOL software.
Postby evasive » Tue Mar 11, 2003 5:03 pm
title says it all, ever since the last upgrade AOL software refuses to work properly. Switch to a regular browser and your troubles will be history...
Postby atang1 » Wed Mar 12, 2003 6:12 am
I am using IE6.0 sp1 with all the latest updates, and I get invalid_session.
I started another window and it bypassed the window that has the invalid_session lock out in my own computer.
It could be caused by mouse click bounce or modem upload data error.
atang1
IE6
Postby SupraDraco » Wed Mar 12, 2003 2:04 pm
Im using original IE6 without any patches and it seems to work good for me.....
SupraDraco
Postby Tolemac » Wed Mar 12, 2003 3:15 pm
I.E 6 with SP 1 and it works no problem. :wink:
Tolemac
Postby MoboCop » Wed Mar 12, 2003 4:28 pm
I have made some changes which MAY alleviate some of the invalid session issues.
This is a security issue that I dont want to go into for obvious reasons.
Less people should now get the invalid session error but if you are using an AOL browser and get the error please try IE or Netscape after you connect to AOL.
Thanks.
MoboCop
Drunken Master
Postby atang1 » Sun Mar 16, 2003 9:34 am
Specifically, IE 6.0 will create an invalid-session, when ISP shut off the modem and restart modem connection. This happen to me twice now. AOL also has random shut off of modem due to denial of service.
However, Private message still works in reply upload.
Invalid_session doen't work with log out and log in again. Unless I start another windows and get on motherboards.org.
Please try modem off and modem back on to see if you get invalid_session? The hidious thing may be the signal sent by ISP to make you shut down your computer because they want to have denial of service.
atang1
Postby jcn » Tue Jun 17, 2003 12:44 pm
AOL is like its an island on the net, it works ok in its own recommended internal sites, but is sometimes uncooperative on the web proper. There is an AOL adapter that you can clear and it will automatically install again. Click on start, all programs, AOL, AOL system information, Utility and then uninstall AOL adapter and clear the browser cache while your there. It will then work better for a while, then I have to do it again. This is AOL V7 info when used with XP.
jcn
Postby J.C.GARCIA » Tue Sep 16, 2003 8:08 pm
just had one of these invalid sessions and i dont use aol :!:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby evasive » Wed Sep 17, 2003 1:34 am
must have had a disconnect then somewhere. Ah, you can try kicking out your temporary internet files.
Postby J.C.GARCIA » Wed Sep 17, 2003 2:56 pm
evasive wrote:must have had a disconnect then somewhere. Ah, you can try kicking out your temporary internet files.
disconnected :?: and i have the browser set to empty the temp folder on exit
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
