It is currently Mon Apr 22, 2019 2:19 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Sat Jan 25, 2003 6:00 pm
Hello. At http://www.motherboards.org/manuals/p/ASUS-P/I-P55TVP4/480.html
I can't get either manual listed (though I want Rev. 2.33 in particular). On that page it says that both files are O bytes, and that actually seems to be the case. When I click on it in Mozilla it does nothing; when I download it with wget I get a file with a size of 0. This makes it seem like a different problem than the one mentioned in a thread from November (http://www.motherboards.org/forums/viewtopic.php?t=11918) that was diagnosed as a corrupt PDF, because wget shouldn't look at the actual file at all -- if I undestand correctly ... but what do I know.
A google search points towards the Asus site, but it's gone now and there's no cache of it. Navigating the Asus site proved fruitless.
If anyone can fix the link or just e-mail the manual, I'd appreciate it very much! Regards,
- Dan
PostPosted: Sun Jan 26, 2003 1:09 am
The whole system was moved to a new server in December of last year. They are still working on getting everything back to 100%.
You can read the post about the move here:
http://www.motherboards.org/forums/view ... hp?t=13289
PostPosted: Mon Jan 27, 2003 4:21 pm
Drunken Master
I thought I was done. Checking the ASUS files it appears I was decieved.
So I am re upping all the ASUS manuals right now. Should be done in the next hour or so.
Thanks.
