It is currently Thu Apr 02, 2020 9:08 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: browser issues
PostPosted: Wed Jan 01, 2003 11:30 pm
recently am only able to log into and read forums or any links with ie 6.0. no longer have 5.5 since getting some bad info about the 6.0 install; i was told it would have the option of being a stand alone install and it wasn't. other installed browsers, specifically opera 6.05 deliver a page of gibberish when you click on the login or forum links. is this permanent? if there is an anti open-source bias i guess that scraps my plans for an eventual linux dual boot installation. it's a shame, since on dialup opera, mozilla and even netscape 6.? are so much faster than ie 6.0 or 5.5. anyone else having this problem?
PostPosted: Thu Jan 02, 2003 9:01 am
Yes - I ONLY use Linux at home and I am also having this problem. I can only access the forum using Opera or Konqueror and they display the page funky. I can only really come here from work now and only for a few minutes.
MoboCop is aware of the situation so hopefully it will be remedied soon.
Please be patient - as I am trying to be. :(
PostPosted: Fri Jan 03, 2003 9:16 pm
Drunken Master
ok I have fixed the mozilla/netscape problem with the forums.
Apparently the forums when using gzip compression and with certain server software installs (note the recent server change when the problem began) cause mozilla/netscape browsers to not display the page.
I have turned off gzip compression and I have netscape working fine now.
let me know if the problem persists for you.
Thanks.
 Post subject: nice fix, and fast
PostPosted: Thu Jan 09, 2003 11:02 pm
this works better than it ever did, thanks
